I'm doing a sprocket for a #25 chain for a clock I'm designing. The issue is that the specifications of the chain establish the diameter of the sprocket. For example, an 84 tooth gear is about 3 inches, and 84 tooth sprocket is 6 7/8".
With the advice of Art, and products from Wildhorse Enterprises to extend the y-axis, I was able to cut a gear 6 7/8" diameter on a Sherline cnc rotary table horizontally. This is about 1 inch beyond the standard table envelope.
This was impossible to do in a 4th axis because I would have had to jack up the rotary table about 2" and lose rigidity, the rotary table would have been offset too far forward, and I would have needed some significant backup plates to prevent distortion if a fly cutter was used. Plus I need more experience doing something like this of course.
Pushing the envelope - a BIG gear horizontally on the Taig mill
Re: Pushing the envelope - a BIG gear horizontally on the Taig mill
Stephen:
Glad to hear it worked out..Large gears are always difficult for us Home hobby guys...
"Stay within the lines."
Stretching and extending the limits is great fun -- I've had parts on my Sherline lathe that weighed more than the lathe.
Users browsing this forum: No registered users and 30 guests
