Gearify
Software helpfull to Gear makers.
Gearify
Re: Gearify
Post by Gearify »
Nate,
"Now, to build involute tooth profiles from this action we need to pick some way to determine tooth phase, and a pressure line."
Wow. This is essentially what I had in mind, only I was of the opinion that "picking" my own pressure line and tooth phase would not constitute something I could advertise as legitimate involute teeth, but rather my own personal bastardization of a precisely defined concept.  :D I have not had time to extensively review and understand in-volute tooth theory to know how much is good enough (I am involved in too many projects... )
This discussion is very motivating to me! If we can come up with a feasible definition I can definitely implement it in Gearify! :)
Here is my question for you though, Nate. By whatever definition you're working with, what is the pressure angle measured from on a non-circular gear? In circular gears, the line tangent to the roll lines at the point of contact is always perpendicular to the line through the centers of rotation (which gives us some nice properties). On non-circular gears (especially the more eccentric ones) the tangent line can be quite far from perpendicular to the line through the center. See the diagram below:
If measured from (p1-p2) I feel that there would be severe disortions where t1-t2 differs significantly. But if from t1-t2, the gears may not "push" on eachother properly and the entire benefit of involute teeth is compromised.
Thoughts?
Nate
Re: Gearify
Post by Nate »
Gearify wrote: Here is my question for you though, Nate. By whatever definition you're working with, what is the pressure angle measured from on a non-circular gear? In circular gears, the line tangent to the roll lines at the point of contact is always perpendicular to the line through the centers of rotation (which gives us some nice properties). On non-circular gears (especially the more eccentric ones) the tangent line can be quite far from perpendicular to the line through the center.
I don't know what the official definition is or even if there is one for non-circular gears.  Art and I discussed the same question in the other thread.   As far as I'm concerned, the preferred usage is the angle off p1-p2.
Thoughts?
Mechanically speaking you probably want to measure the angle from p1-p2 and live with the distortions.   That's what I was trying to describe, and, mechanically, you want the action to be close to that line.  There's a lot of freedom in tooth profiles, so the roll line tangent line can somtimes also work.
In the illustration, if we imagine that we're turning the red gear clockwise as the master and the yellow gear is the slave and the gear flanks are roughly perpendicular to the t1-t2 line, then it's likely that the gears would just separate.
Nate
Re: Gearify
Post by Nate »
I don't know what the official definition is or even if there is one for non-circular gears.  Art and I discussed the same question in the other thread.   As far as I'm concerned, the preferred usage is the angle off p1-p2, but I worked this stuff out for myself.  Other people will have other notions.
Thoughts?
Gearify
Re: Gearify
Post by Gearify »
"so the roll line tangent line can somtimes also work."
Sounds like this could potentially be a user option!  :D
I do wonder how the distortions would appear when the roll-tangent line is significantly off-normal to the center-to-center line...
Here is another question.
We can define the pressure lines as a series of "snap shots" where the line is chosen to pass through the contact point at a particular point in time. So there is in a sense a "jump" from one pressure line to the next as the position of the line switches for each tooth, to pass through the varying point of contact of the roll lines. This jump may produce some abrupt changes in stress and pressure that may be undesirable (am I wrong?).
One could, however, define a MOVING pressure line.  Such a pressure line would always be intersecting the point of contact between the roll lines, and the point of contact would linearly travel along this "floating" pressure line.
This is similar to how a Cubic Bezier curve is generated. Imagine the green line below is our "floating" pressure line. The orientation of the line is defined by either of the two "pressure angle" notions we defined (this is constant if measured from (p2-p1) as described earlier, and continuous if measured from (t2-t1)), and the position of the line would be continuously defined by the point of contact on the roll lines...
What do you guys think?
Re: Gearify
I think youll find the pressure angle is measured not from the pitch circle, but from the base circle, so if we shrink the ellipse by the base circle amount,
then compute a tangent between the two offset base ellipses, that would be the pressure angle Id use ( and do currently) in computing the involutes.
I think Nates idea is a really good one. Ill probably play with it in the coming months to see if it improves on hobbing, but I have read papers
on the hobbing being superiour simply because it deals with degenerate solutions to Nates idea. Its like the tips of the teeth on high K areas
of the curve, the hob finds it naturally, the involute equations start to produce some nasty overlap that needs to be dealt with.. at least thats
what Ive experienced so far.
Re: Gearify
Michael:
As an example, in your drawing, Id imagine the proper line of action is if you moved T1 to a 1/4 inch inside the red on a line from
c1 to p1, and then places t2 at a line crossing pitchpoint to a point 1/4" inside the yellow...that woudl be the proper line for that gear.
Nate
Re: Gearify
Post by Nate »
ArtF wrote: ...
Right, the hob is good for finding clearances, but if the profiles are degenerate, then 'virtual hobbing' will produce bad gears.  (I.e. gears that lose mesh or with rotational ratios that are inconsistent with the roll lines.)
Nate
Re: Gearify
Post by Nate »
Gearify wrote: ...
The pressure line is stationary in the reference frame of the pitch point. In any reference frame where the pitch point is moving the pressure line will be moving as well.
In this video the pressure line is the red line, and the red dots are points of contact.  Can you explain what time in the cycle the "jump" you're concerned about occurs?
https://www.youtube.com/watch?v=14yMFdgWM-A
Gearify
Re: Gearify
Post by Gearify »
Let's say that P(t) is the point of contact between the roll lines at time t. The line of action (as you defined it) passes through P(t), and is oriented based on the pressure angle.
Suppose the pitch point begins contact at time t0 and moves smoothly along the line of action until the next tooth is engaged at time t1. Now a new line of action is engaged and will pass through point P(t1).
For a circular gear, P(t0) = P(t1). for a non-circular gear, they are most likely not equal.
So imagine in the video you posted, imagine that the height of the red line would instantaneously jump to a different vertical height every time a new tooth engaged.
Nate
Re: Gearify
Post by Nate »
Gearify wrote:...
The pitch point is moving continuously along a continuous path.  There's also a continuous rotation.  What does your math education tell you about the composition of continuous things?  Also, does continuous motion 'instantaneously jump'?
The "dots" do jump back to the start of the line of action - that's the sawtooth phase I described - but the motion of the line of action as a whole is going to be continuous in any setting where the motion of the gears is continuous.
BTW:  If we imagine that the gear in the video is rolling along a stationary rack, then the only way that P(t0) = P(t1) is if t0=t1.  You're not thinking in terms of the reference frame of the pitch point.
Gearify
Re: Gearify
Post by Gearify »
I think I'm not communicating what I am trying to say properly. I do understand composition of continuous functions is continuous. I think we're talking about two different things but I'm not sure where our disconnect is yet.
In the above diagram, the circular gear has a line of action who's position (I'm talking about the entire line segment's position) remains constant relative to (let's call it) the observer. But the non-circular gear has a line of action that is at a different horizontal location. So, either the horizontal position (relative to the observer) of the line of action would need to jump to new horizontal position after each tooth engagement, OR, the location of the line of action is allowed to vary continuously over a single tooth (in which case the "dots", which are interpolating across a moving line, would actually follow a continuous curve).
Do what I' m saying make more sense now?
Nate
Re: Gearify
Post by Nate »
Gearify wrote: ...
It's the latter - the pitch radius can vary continuously over a single tooth.
Re: Gearify
I think thats true since the tangents to the base circle vary from point to point the line of action is variable over time and over the run of each tooth.
  I tried an appraoch I recall where you calculate the base circle, then unwind the involutes point by point from that base circle..
(. problem had something to do with actually computing a base circle in convex areas.. requires looking to the inside curvature, not the outside..Negative curvatures caused me trouble as involution switches polarity so to speak....Hard to explain till youve coded it I think, or its just my weaker math skills, ). Perhaps, Michael your comment on the sudden shift is related to that thought, there is a point at which the involute shifts direction as K changes polarity. That could by considered a sudden shift...conceptually..though its really a reversal with deceleration and acceleration into the new direction of curvature.
Nate
Re: Gearify
Post by Nate »
ArtF wrote:... problem had something to do with actually computing a base circle in convex areas...
When you have a negative curvature, then the center of the osculating circle is on the other side of the roll line, and when the curvature is zero, the circle is degenerate.
I have to say, my eyes crossed a little when I read "... shrink the ellipse by the base circle amount ..." earlier.
As far as I can tell, base circles are great when you want to generate the gears on paper using physical tools like string and pencils, but really only confusing when we have the analytic power of modern computers available.
P.S.  Is the "WiredMinds eMetrics" in the preview supposed to be there?
Nate
Re: Gearify
Post by Nate »
As far as I can tell, base circles are great when you want to generate the gears on paper using physical tools like string and pencils, but really only confusing when we have the analytic power of modern computers available.  Though if they work, by all means, keep using them.
