rebooted and tried again ,set time 1000mS power 72.7%
result 141.981 mS of 72% pwm
Variable laser power
Re: Variable laser power
tried another pc , same result.
did notice the first test after a boot did for a 10 seconds test did fire led for 10 sec , all subsequent tests fail time wise
Hi Rich:
So the LED also fails each time after, or does it instead lie and stay on the right time?? ( I imagine you need at least a few second test to tell. )
that's why I tried 10 secs, the first time led is on for the prescribe 10 sec , all subsequent tests the led is on for a few hundred mS at most
its only the test fire routine where the trouble is , in actual use the laser seems to be driven appropriately
