Auggie crash
DanL
Re: Auggie crash
Post by DanL »
yep thanks art
DanL
Re: Auggie crash
Post by DanL »
Art I just found why I could not get YaNvrNo's script to work, it helps if you can spell
DanL
Re: Auggie crash
Post by DanL »
And copy and past does not always work correctly some parts need redone, but when you are typing sometimes the autofill does not come up, it will happen over and over again.
closing down the scripture and starting it again does not help.
I have to restart Auggie to get it to work then it stays okay for sometime or it will crash as soon as I hit enter when the autofill pops up.
the board is meant to be here on wednesday, tuesday your time so will see what changes then.
Re: Auggie crash
  Ive just rewritten the autocomplete so its much more usefull as it now
only offers commands that belong to the initial command..
  Also a serious bug in the planner was found and repaired that helps smooth
things out. Each day I find a few crashes as I do changes and fix them up..
reminds me of the old days of mach2.. without the pressure.. :)
DanL
Re: Auggie crash
Post by DanL »
cool I will run the new version and see if I have the same problems, they were easy to reproduce, as long as I spell things correctly.
DanL
Re: Auggie crash
Post by DanL »
it does not crash on the autofill now it's working better, when I try to step through the code it crashes hard YaNvrNo spiral script, it does the same if I just step in then step out,
and if I step in then kill all threads hit run, then hit run again crash.
I will try another code now.
Re: Auggie crash
Found a few more errors this evening, and recoded an important module, it may help alot. Speed of the interface is now increased by a factor of 4, so lets see what happens after tomorrows release.
DanL
Re: Auggie crash
Post by DanL »
cool I will play with other code's to see If I can find more ways to crash it, I will do some real stuff when the board get's here
DanL
Re: Auggie crash
Post by DanL »
well all other code that have been posted are fine no problems at all.
whent back to YaNvrNo first code if I have Spiral(50,0.1,0.2,0.5); in the code, in the scripter it crashes everytime, if I have this Spiral(50,0.1,0.2,0.5); in the script MDI page it runs fine.
so that the bug
