Bevel Machining diagram
For discussions of the various methods of Bevel Machining.
EdL
Re: Bevel Machining diagram
Post by EdL »
Thanks for the quick response.
Have you ever tried cutting bevel gears with a milling cutter meant for spur gears?
(the kind with multiple teeth that cuts the full form space between the teeth)
I think it may be possible with two passes with the blank rotated slightly and the cutter slightly offset.
I had been thinking about that process for a while when I discovered Gearotic Motion.
I am excited about being able to generate the tooth form using 4 axis code.
You mentioned in the release update something about engraving the bevel gears with the blank flat.  Does this mean the bevel gear shaft axis will be vertical and parallel to the tool?
Ed
Ed:
    An involute cutter wont work on a bevel as the tooth form shrinks as you approach the cone tip. Its this shrinking
involute form that usually the troublesome bit to do in a bevel. Its why special machines are used to make them generally.
  When the recode of GM is complete ( which will take awhile yet. :) ), I will be looking at my options for bevel Gcode
as its the hardest module to do. I'm thinking that its possible using a pocketing strategy such as a waterline
pocketing with the axis vertical. While this would be slow, it would be generally easy for a person to do. Im continously thinking of better ways to do things as I untangle the rats nest of code which is GM and create a new cleaner environment
for the GT's interface and outputs. So feel free to input suggestions as I go, you may not see the results till next season,
but Im considering all idea's as I go forward.
Wod
Post by Wod »
    Way back when I was an apprentice I seem to recall one of the old guys telling me about a formula for using an involute cutter for 'faking' in  a bevel. If I remember correctly, you set the angle of the bevel by angling the dividing head and cutting all of the teeth. Then you rotated the dividing head a certain amount to one side and lowered the Z axis a certain amount to center it on the original gear gap on the small end and recut all of the teeth, which widened one side of the tooth at the large end. After recutting  all of the teeth, you rotated the dividing head the same amount in the opposite direction and raised the Z to recenter it and then cut the other side of the teeth which widened the rear of the other side of the tooth but left the small end alone. I think the formula is in one of my old Machinery's Handbook or one of my old Audels Machinists books. I'll dig through them and see if I can find it.
Wiley
Hi Wiley:
  I have heard of that, but Ive refrained from experimenting with it as I dont really understand the math
of it, how the involute is affected. Let me know what you finf, perhaps it will help.
Wod
Post by Wod »
    I couldn't find the table that I was looking for in any of my old books, but I did find this explanation. http://www.archive.org/stream/americ.../n148/mode/1up . The explanation starts on about page 145.
Wiley
John S
Post by John S »
You still have to hand file the smaller end above the pitch line for the length of the tooth to correct the DP at the smaller end.
JustinO
Post by JustinO »
Does your straight flute bit straight bevel gear cutting method allow you to leave the rotary axis at 90 degrees for all pitch cone angles?
--Justin
Justin:
No, in all cases the 4th axis must be tilted to the cone angle so the cutting is perpendicular to the tooth profile.
Ill be looking into a waterline type of flat cutting for the fall re-release. Its my intention to have a much higher
level Gcode module so you can see the toolpaths and such as you setup for Gcode cutting.
JustinO
Post by JustinO »
You've obviously got more on your programming plate than I would ever dare to consume....
But just for the sake of conversation...
In your straight flute method, the cutter is cutting a plane, a vertical plane. And I assume that plane includes the apex of the pitch cone. If you imagine that plane is sticking to the tooth it just cut along, and you rotate the rotary axis to the horizontal, as one with the gear blank, the gear tooth, and the plane that was just cut, you will see that all it would take to make that plane vertical again is a rotation of the rotary axis. If the plane is vertical,  you can cut it with your straight flute bit. Instead of an XY path, you would  have an XYZ path, and the angle of the rotary axis would be slightly different.
It might be a simpler setup for some people than having to have and set up an angle plate to a very particular angle.
--Justin
Hi Justin:
That is one reason I think Ill do a module specificaly for such things. The reaosn for the tilt is that the vertical side of the flute is shaving the vertical wall of the tooth in a horizontal plane.  Tilting the 4th axis allows the tooth plane to be horizontal, if it wasnt then the flutes vertical axis is having on a tilted axis, and the math indicates this shouldnt be allowed. Its very hard to picture and isnt very intuitive, but while its possible to do it
as an x,y,z in the case of a bevel untilted, the math more complex due the the elliptical shaped edge of the bottom of the bit when considered from the perspective of the tooth plane. (Im not sure Im explaining that very well, but its when you actually start to implement the model that the shortcomings come into play in the math of the tangental shaving routine. )
  We'll have a much more detailed conversation about this as I get to the spot where a new Gcode module becomes necessary. Im currently working on the new spoking module to eliminate all the weirdness experienced by some with the various spokes as they get complex. The new one is just testing today and is extremely stable. I hope to add a dozen more spoke types and then start on adding all the variosu gears we currently have in GM, then its on to a new output module with new Gcode. At that point we'll begin a conversation about what types of operations people would like and in what orientations.
Micheal Cranford
Post by Micheal Cranford »
ArtF wrote: Art said:
    "An involute cutter wont work on a bevel as the tooth form shrinks as you approach the cone tip. Its this shrinking
involute form that usually the troublesome bit to do in a bevel."
That statement is not totally correct since wheel shaped (i.e. non-shaper) bevel gear cutters exist and have been in
use for many years. An involute spur gear cutter can easily be used to make straight cut bevel gears. Wheel shaped
(i.e. non-shaper) involute bevel gear cutters are simply thinner than standard involute spur gear cutters for the inner
face diameter clearance. Using a spur involute gear cutter to make bevel gears requires some geometric calculations
to determine which involute cutter to use, and it most commonly requires three passes per tooth. As the time permits
I can generate a spreadsheet to ease the calculations for the non-math inclined and, if possible, post it here if there is
any interest. It should be relatively trivial to add using involute gear cutters to Gearotic since the geometric motions
are much simpler than cutting out the tooth form using endmills.
The trick is to choose an involute form whose width is correct for the inner face diameter rather than the outer face
diameter. Doing this allows the first pass to cut the inner face involute form correctly. Then the 2nd and 3rd passes
are done by slightly rotating the gear blank and offsetting the cutter such that it exactly fits through the inner face
clearance that was created by the first pass. The 2nd and 3rd passes remove material from the adjacent gear faces
with the majority of material removal being done at the outer face diameter. This method does not require any filing
after the gear is cut (every gear is ready to use), unlike the similar method that selects the involute cutter based on
the outer face diameter. I have some four dozen different gear cutters and they can all be used to make bevel gears
just fine.
Micheal;
Point accepted and appears proper, however I lack expertise in this area and can't say for sure, but I do remember some issues existed as the cut approached the tip of the cone and tooth became really small. Art is away for a few weeks but I'm sure he'll reply with his thoughts on this matter upon his return. Anyone out there care to share their opinion on this?
Bob ???
Micheal Cranford
Bob:
I was being very brief in my first post, so to further expand on this there are at least two different styles of bevel gear tooth
profiles. The first type will be referred to here as straight bevel gears and the second style as parallel depth bevel gears.
In the former you can visualize the mated pair of bevel gears as being two cones with coincident apexes with a line of contact
between the two cones.  The tooth shape at the maximum cone diameter is linearly scaled down as you approach the apex.
Hence the height and width of each tooth shrinks to zero at the apex.  These type of bevel gears are generally made with a
specialize shaper rather than an involute cutter.
In the latter bevel gear type each gear tooth varies in width as you approach the apex but the tooth height could be constant.
I said "could be" because there are different ways of making parallel depth bevel gears using an involute cutter. In one method
the maximum diameter defines the tooth shape so the smaller diameter end of each tooth needs filing so that the teeth are able
to mesh without interference. It's also the case that the involute cutter must be thinner than a normal involute cutter to fit into
the space between the teeth at the smaller diameter end.
In the easier to make method the smaller diameter of the bevel gear defines the tooth shape so a standard involute cutter can
be used instead of a bevel involute gear cutter. This method has the advantage that no filing is required to get the teeth to fit
with sufficient clearance. In both involute gear cutter methods multiple passes must be made with small rotations of the work
piece and small offsets applied to the cutter achieve the correct tooth width since that still varies with distance from the apex.
My original post was referring to the latter parallel depth method of making bevel gears.
John S
Post by John S »
Micheal is correct in his statement where parallel depth bevels are concerned. you can use an involute cutter with no filing.
However what I term 'proper' bevels cannot be done with one cutter to a finished shape because both the tooth shape and depth tapers.
As Micheal says they have to be done on specialist shaping machines. There should be no reason why Gearotic cannot do these bevels because the tool is mimicking the action of the shaping tools in that it never cuts a full profile at any time but slices.
Silly bit of obtuse history here. The parallel depth bevel was introduced commercially, didn't say invented, during WWI so machine shops could easily produce acceptable bevel gears because of the lack of dedicated gear cutting machines.
After WWI the demand went down but appeared again in WWII and in the UK this forced the British Government to get Drummonds to hand over the Drummond lathe to Myfords so they could concentrate on the Maxicut range of gear shapers.
Without this kick start the Myford lathe would probably not have been developed.
This taking away of products from companies was rife during WWII. The government took the jet engine away from whittles Power Jets company and gave it to Rover. Rover made such a botch of the job that they told Rolls Royce to give the detuned Merlin engine that was fitted to tanks and have the jet engine in return. A move that made Rolls Royce what it is today.
Hi guys;
Micheal thanks for the expanded details and John for the knowledge and history. As I mentioned I'm no expert on these, just learning. All I really know at this point is they are so much easier to print..lol
