Amusingly enough, I'd *just* seen that video! The technique would definitely work I think (and I've even got an indexer), but alas my laser doesn't have the headroom to fit everything.
...although, now that you mention it, I do wonder if perhaps I couldn't cut the crown teeth as a rack, using the variable-power engraving to add a bevel cut to each tooth (so that they come out separate, and can be reassembled into a circle). With some kind of centering-ring jig, and enough glue, it might actually work. Although, at that point, I should probably just knuckle down and clear out the garage so that I can access my mill and lathe, and start working again with the proper tools ;)
Gear tooth as a height map?
Re: Gear tooth as a height map?
The original post had me wondering whether you wanted a "polar" height map or "rectilinear" height map. This makes a lot more sense.Mand wrote: It's occurred to me I've been accidentally cryptic in all of this -- what I'm trying (again, foolishly) to do is develop a way to create a crown gear or rack gear using an engraving laser.
Users browsing this forum: No registered users and 12 guests
