Cam Grinding coding
Re: Cam Grinding coding
Thats clever....
2.5D cam gcode could be handy for Kinetic and Rube Goldberg type devices, although that to-do list may already span too many volumes to fit on your (virtual) bookshelf. Isn't a grinding wheel basically a really big cutting tool, so the output would essentially be the same?
While I don't remember the reference, and google fell short, I read some time back in one those old out-of-copyright books that if gear making hadn't become "easy" that cams would have had a lot more prominent part of machine design.
(OT) Really like the celtic knot laser plugin. Any plans to make a routable version? Expand it into a CNC Rose Engine?
Cam grinding SEEMS simple same with Crank Grinding , BUT IT AINT. When grinding a lobe on a rotary axis the point of contact of the WHEEL changes with the profile of the lobe as it rotates. There is a formula or three to correct the Z(grinder infeed) so that it translates correctly as the A (rotary) rotates.
Other wise the lobe you think you ground is NOT correct to the original profile. ]
ALSO as the wheel wears it must be compensated as well. That was the reason for cross over grinding a lobe pair( or as many as you select, you can do the entire camshaft at one time if you wanted . It just takes TIME to GRIND.
Just a thought, (;-) TP
Actually, I intend to add an engraving module to the CNC grouping, so I first needed
an engravable object and celtic knots sounded good to me for that. The knots will appear
shortly..
shortly..
Paul Rusconi
Hi
There is a nice cam grinding program here that is worth a look http://gcam.lucasemail.org/
GCam Forum
https://groups.yahoo.com/neo/groups/GCam_CNC/info
Paul
GCam Forum
Paul
(;-) They make a LOT of assumptions in that program(;-)
I sure am.ArtF wrote: . Any out there also interested
in cam grinding as an output?
Long wanted to do model engines, had the machines but not the time. Now that is reversed, have the time but no machines except for a small router and a bigger much stiffer one half constructed. Found Gearotic in my search for pulley solutions so bought it to make my own, thanks Art.
Next on the list is a small cnc lathe, 500mm BC, with a special focus on grinding , looking for an old mill table for a base, about 1 meter, to take the 35mm Hiwns.
Cams and cranks have always been the stumbling block for me and a cnc lathe with a focus on grinding should make that a lot less of a pain in the butt. Software for it is a stumbling block though, i have seen the online gcode generator one but don't like being tied to something that could go off line at a moments notice.
I hope this idea is still floating around in your mind somewhere, poised to surface about the time the lathe is finished ;D
As someone else noted, don't need a special machine. Its easy to adapt to a lathe or mill if only some decent software existed. Is it a case of build it and they will come or am I the only loon on the planet :D
Mike
Hi Mike:
Desire noted. :)
Desire noted. :)
2.5D or 3D printed cams that don't require a 4th axis or grinder would be nice, too, if cams ever make it to the top of the list.
CAM was an unfortunate choice of acronym, makes googling (or binging :) ) for cam creation a lot harder.
Hi Kirk:
The next module is making a gear ( or cam) from a formula you enter. SO a 3d printed cam isnt far away...
