getting shaft holes to appear in plate
Re: getting shaft holes to appear in plate
Attached is my file. Thanks for looking at it. It isn't very complicated, just three shafts.
David.
David.
Hi David:
Try this one. I'm not sure how, but your plates were moved a long way from center so you couldnt see them. I moved them back to
center and you should now see them and the oles in them.
Yes it worked. I see how if I zoomed waaaay out I was able to see the plate. No idea either how it got there. How did you move it? I wasn't able to drag it back. And even with your version you sent back to me I can't seem to move the plates around.
David.
David.
I may have got it. In the plateing mode I'm able to move the plates around. Is that right?
David.
David.
David:
Yup, on the plating screen you can select any view ( top, left..ect..) and click to move the plates around.
By doing so you center them in each plane to match your design. The holes move as the plates do.
Is there a way to remove the plates? Maybe it's not really necessary cuz if I don't want them I can ignore them, but I'm just wondering. I tried right clicking on the front plate and selected remove. I was warned: This will remove all mechanisms, are you sure?
I thought it would just be the plates but it did indeed remove everything. Of course my work was saved, so it was fine.
David.
David.
Dave:
Just go to the plating tab, and uncheck the ones you dont want.
