GT2 3mm Pulleys
Paul Jeran
Re: GT2 3mm Pulleys
Post by Paul Jeran »
Thanks for the thoughts.  I can understand wanting to do it right.  I will give the 5-3mm conversion a shot.  If you do get the info you need to generate the tooth profile, I will also look forward to that.
Paul
Re: GT2 3mm Pulleys
Paul:
  They are in todays release, BUT be cautious, they look a bit off to me, might not matter, that happens in interpolated data,
but let me know how they stack up.. Thx for the pointer to the data...
Paul Jeran
Re: GT2 3mm Pulleys
Thanks!  I will generate some gears and let you know how they work.
UPDATE:  Tried to generate a 10 tooth gear - yes pretty small.  It looks like a series of vectors that don't quite tie togehter.  I will try to attach a PDF of what the DXF looks like.
When I try to generate a 25 tooth gear I get a Error Found Gearotic:11, Attempt Recovery? - I tried several times to recover and it just loops around to the same error.
Paul
Re: GT2 3mm Pulleys
Paul;
Have you tried switching over from inches to mm in your setup?
Re: GT2 3mm Pulleys
Paul:
  I did discover inch mode wasnt working, a fix was generated so redownload and you should find its fine..
Paul Jeran
Re: GT2 3mm Pulleys
After too much business travel got back to the gears.  The profiles look a bit flat on the tips compared to the other GT profiles.  When I cut a 55T gear, the mesh was off with the 180* of engagement.  I went to the GT2-5 profile and re-sized it to the proper diameter and it seems to be working fine.
Thanks again for the effort on this.  It is pretty nice to be able to knock out a gear for a project as needed.
Now that the rotary is complete, time to get back to the clock!
Paul
Re: GT2 3mm Pulleys
Paul:
  Yes, tyhe shaping can be difficult to get right  if the spec isnt just so.. Its why I always hesitate to try to
duplicate a shape unless I have something more definitive. The GT2 I did was based on a belt apparently, so
I expect its a bit off. Ill wait and see what feedback occurs over the years.. :) , eventually Ill find the
right data. Glad to hear the 5mm works when scaled.. Maybe Ill just change the code to scale the 5mm ..dunno why I didnt
just add it that way..
