3D printers
David Sohlstrom
Re: 3D printers
Post by David Sohlstrom »
These folks build a very unique 3D printer.  http://seemecnc.com/
Dave
Re: 3D printers
I like the style of those, I almost went that direction... Id like to see some samples from one done by an owner.
BrianB
Re: 3D printers
Post by BrianB »
Yeah, I've seen others like it. They do look different.
Thanks Mr. Dave
Martyn Hogg
Re: 3D printers
Post by Martyn Hogg »
I bought a reprappro Mendel kit for about ?500.
It was fun to build, gives pretty good results and I use either Rhino / Grasshopper to generate 3d models or Solid Works then save as STL file, use the free cloud based STL repair service on Netfabb, then slice it using Slic3r and print it using Pronterface! Er, simple!
If you have ?2-3k to spend you must be able to get a much better solution! I would certainly look for a printer that can print a second water soluable "support" material if you think your prints will often have overhanging sections as this is often the tricky part to getting good prints. If you are only ever going to print shapes that are straightforward extrusions of 2D shapes then you probably won't need support material in your 3d prints.
In the UK we are starting to see some high street retailers selling printers now... a ?700 self assembly kit in Maplins and a ?1200 ready to print printer in Curry's too.
For the software its all about getting good STL files, then Slic3r is easy to use and should generate good g-code for your printer software.
I am not aware of any technological benefits of ?2-3k plastic extrusion printers over the ?500 versions other than they come ready assembled and with a nice looking box, so if you are comfortable with some basic soldering and following assembly instructions you could save a lot of money with a self assembly kit. Also, some of the ready built printers appear to have material cartridges which look like they could be expensive compared to just buying a reel of ABS or PLA plastic.
I have a feeling that whatever you get, it will require you learning a few printer specific tricks and tips to get the best out of it!
Re: 3D printers
Check out Nicholas Seward's Simpson and Wally printers for something even more different.
Re: 3D printers
That IS unusual...
Re: 3D printers
A lot of the design was a community effort, partially described in this topic.  It's been interesting watching it evolve.
BrianB
Re: 3D printers
Post by BrianB »
Thanks for the responses.
I agree, those are unusual.
I'm starting to lean toward the MakerBot Replicator X2. I like the dual print option. They advertise that it will print 100 microns. I spoke to a sales rep and he claims that 50 microns can be achieved with "some modifications". That would be great, if indeed it is possible.
Thanks again for the comments.
Brian
Re: 3D printers
50 micron layers aren't that hard if you use a small nozzle orifice.  I've done them on my Printrbot, using a home made 0.3mm nozzle.
You need to print a lot slower, and use a narrower extruded plastic width (should be configurable in your favorite slicer), since the low heights don't allow the plastic room to move very fast.
Users browsing this forum: No registered users and 112 guests
