GT2 Timing Pulleys and Belts
epicycloid
Re: GT2 Timing Pulleys and Belts
Post by epicycloid »
Are there any other "hints" for settings to produce the best output for the GT2-5's?
I read the old post here http://gearotic.com/ESW/FavIcons/index.php?topic=637.0, but wondered what the reccomendations are these days, or if they have changed since then?
TIA,
--Jon
I see that hread had to do with large tooth counts in a gt5-2 causing the stl file to look bad. What usage are you wondering about?
If you need a good dxf, the dxf should be good out of GM, but if you need an STL of one, then save a GM project , load it into GT
and it will reextrude to a high resolution STL.
  It all depends on the method youll use to make it, but Im assuming we're talking either dxf or STL model?
epicycloid
I just need to produce a dxf for conventional machining on a VMC (Mazak). But since I won't be doing the machining, I'm a tad worried about what settings I should use to produce the best/correct resolution dxf output, or if I have to tweak something in particular?
I'm playing around with various sizes/ratios right now, but probably aiming for something in the 160 to 200 tooth count.
I guess I didn't see that that thread was specifically referring to issues with an STL.
--Jon
Users browsing this forum: No registered users and 171 guests
