Can't load Libraries
Re: Can't load Libraries
I tried deleting Libraries folder and reinstalled ... no success
tried uninstalling Gearotic, deleting enitire Gearotic folder and reinstalling... no success
tried on another XP sp3 machine fresh install of both ... no success
I'm using the latest develop release. Also tried the last release from this spring ... no success
It's working fine on 2 desktop win 10 machines
Maynard
Maynard
I wonder is its a winXP thing, I use Win7 here, but seems odd the program runs and ust the library load fails.
Try this, turn on debugging on the ribbon bar menu under config, then try the library button, see what the log says,
it shoudl tell us why the error and what didnt initialise. Also, try turning on the scripter, then hit the library button, errors
should be printed in the log abotu why the library failed..
Seems like it may be a ui issue, and the libraries aren't being selected.
First screen shot is all libraries selected. Noticed the check boxes don't turn green,as they do on win 10 machine. Also the icons are in random state each time I open the Libraries dialog.
Second screenshot is scripter after I hit OK on Libraries dialog. Also attached the errorlog with log checked.
Maynard
Maynard
HI MAynard:
Seems to indicate a hosed profile file. Can you send me the profile your using? Ill
take a look. There is a key in there that triggers a no library load and the error "No libraries loaded".
The key is [ScriptTypes], [Scripts] and should be set to 1..
Thanks Art
I couldn't find those keys in the profile, so added them set to 1, under [General], but it made no difference.
Here's my original profile changed to a text file.
Maynard
Maynard
Update:
You were correct Art,
Compared the profile on the Win 10 machine to the XP machine and the [Scripts]and [ScriptTypes] keys were missing. Earlier I just added Script=1 ScriptTypes=1, but after looking at the older profile realized there was more to it.
After adding this to new profile, all is well. As most people are simply updating their current install, I'm guessing this is not being added to new installs.
On a side note, the XY motion is great with network delay set to 0. Moving a belt driven gantry with 3 phase steppers at 900 inches/min.
Thanks for the help!
Maynard
Maynard
Maynard:
Glad to hear the motion is good. Ill take a look at those keys and their generation. Thx
for this thread, it helps to have such information on archive. Auggie isnt used by many,
so details like this really help over time.
Is that a heavy machine? I suspect Auggie works best with weight, jerk limiters usually
do. I did find here that tuning is picky as to the job at hand, may have to add a multi-jerk profile
setting for different types of work in the end. :)
