Bob,
I have tried to design a spoke in Cut 2D Desktop, I sucessfully
export the DXF file to a folder and copied the file into Spokes...
I used a very simple design about 5 different times but it never will load in the
wheel I picked.
My spoke is much simpler that the existing files...
RR
Re: Hi Art,
Re: Hi Art,
Rocket;
Check your messages, I sent you info on how to install your existing license onto your garage computer. Now as to spokes, what I said should work, but tell you what, send me your dxf, I'll test it here and will pass it back to you..
Re: Hi Art,
Rocket & Bob
If the SPOKE designs are similar in function to ones created for custom indicators, then the problem might be that the shapes Rocket is creating are simply lines instead of closed shapes (polygons, poly-lines, etc.)
Bill
Bill
Re: Hi Art,
Bill;
Your right, that';s why I asked for his dxf so I could check myself. Thanks for your input..
Re: Hi Art,
I was using inches instead of MM....you must use MM.BobL wrote: Bill;
