about to start...zero help?
MJBoluijt
Re: about to start...zero help?
Post by MJBoluijt »
My first attempt for making epicycloid gear with slitsaw, at first I have chosen maintain high, the teeth were cut off.
But after that all is ok. Modul 0.5 Z 28
Kind regards
Rien
Rien:
  Great job. Looks good ( other than the maintain height tests. :) ). Looks
like not a bad epicycloidal from a  slitsaw. With all the bugs and changes from last year
the generation of gears from the 4th axis module seems to be getting near bulletproofed.
  Thx for the example..
MJBoluijt
Post by MJBoluijt »
Yes the form seems good, there was one fault in the file, see a part of it here, no F before the 1000.0
Of course that was easy to change.
Regards,
Rien.
(  No Epilog set )
( Gearotic 2.0 GCode Begins. )
( Object Spur  )
( Job will comprise 1 rotations of the rotary axis.  )
( Tools Used:  )
( Rooting: EndMill2mm Tool #1  )
( Wall Straightening: EndMill2mm Tool #1  )
( Tangential Shave: EndMill2mm Tool #1  )
( Blank size for this gear :  )
( Diam: 15.5543 Thickness: 10.000 )
( SlitSaw Posting. Zero to side of blank.  )
( Root Clearance Begins. )
( Tool change to EndMill2mm )
M6 T1
G43H1
M3 S1750
G0 X23.403  Y0.250  Z0.000  A0.000
G1 Y-1.572  Z-0.000  1000.0
G1 X-23.403  F3000.00
G1 Y-1.572  Z-0.093
G1 X23.403
G1 Y-1.572  Z0.093
G1 X-23.403
G0 Y0.250  Z0.093
G0 X23.403
( Root Wall Begins. )
G0 Y0.250  Z0.255  A3.214
G1 Y-1.563  Z0.255  1000.0
G1 Y-1.563  Z-0.255  A-3.214
G1 X23.403
G0 Y0.250  Z-0.255
( Tangential Shaving Begins. )
G1 Y-0.777  Z0.255  1000.0
G0 Y-0.000  Z1.306  A11.846
G0 Y-0.810  Z1.306
G1 X23.403
This is my home made A axis, made with a small harmonic drive.
Nice Drive:
Sorry about that floating 1000, Ill find that error and kill it, I thought I had it before.. :)
Headsmess
Post by Headsmess »
oooooh, tell me more about this harmonic drive...like, how much, from where? :)
and how is it on backlash?
MJBoluijt
Post by MJBoluijt »
Look here at regular time
http://www.ebay.com/sch/Electrical-Test ... ?_from=R40 and search for Harmonic Drive.
Sometimes there are cheap ones. Mine was $ 130.00 Take care you buy the Harmonic drive and not the harmonic gear.
No Backlasch  my drive  is about 80mm, 50:1
On a radius of 65 mm you can measure some flex when you make radial force, about 0.01 to 0.03 mm
The cross rollerbearing is strong enough for holding a 80mm 3 jaw chuck
Headsmess
Post by Headsmess »
yep, did the fleabay check and found a few pop up for under $100. yours looks to be of a lot more compact than what i was seeing...
would really prefer a hollow shaft type but hey... what i saw was more in the region of $400+...ouch. matter of luck/patience i guess.
i always liked the idea of making one by using a toothed belt inside out but noone has yet described how i will make an internal pulley with the correct tooth profile!
