Tiny gears
BBlinds
Re: Tiny gears
Post by BBlinds »
The 3 lobbed profile is for the tilt rod on a vertical blind.
Is there anyway to generate a set of crown gears with gearotic?
Re: Tiny gears
  Crown gears cannot be made as yet, I didnt see a way to easily construct them..
They are on my lengthening list though...
Re: Tiny gears
BBlinds wrote:the main problem coming from the motor producing so much torque that it was breaking the gears when putting the output into stall. With the size of the gears now it breaks the motor on stall which will be controlled by a overload circuit on the electronics side later down the road
Missed this the first time around.  Have you considered using a magnetic clutch?  Take the wheel from a caged gear, make two of them, fill the holes with those super strength tiny magnets, and adjust the number of magnets until it starts slipping where you need it to.  Iirc Art made one of these quite some time ago.
BBlinds
Re: Tiny gears
Post by BBlinds »
Nice idea but not enough space!
rogerx3
Re: Tiny gears
Post by rogerx3 »
Nice work.
Users browsing this forum: No registered users and 68 guests
