David C. Roy's Monarch II
DHelmick
Re: David C. Roy's Monarch II
I think you may be right about small magnets in the "butterfly" shaped pawls..After watching the close up video over and over till my eyeballs almost fell out...I see the "free" pawl move quickly towards the center...(brass rods) when it nears the trapped Pawl...no matter what direction it is turning...but when it goes backwards....this action moves it towards the pin..the free pawl then pops out clears one pin and then gets caught on the next..releasing the spring energy.....
https://www.youtube.com/watch?v=ZfBsNsWvvJw
Hmmmmm...I am going to experiment with small rare earth mags and see what happens..
Dale
Dale
Dale:
Its how my bat does it.. a small rare earth pulls the latch inwards at the rigth point... I get the feeling he doesnt use any though...
I think so too...I'm going to order a few small rare earth magnets and run some tests.DHelmick wrote: I think you may be right about small magnets in the "butterfly" shaped pawls..After watching the close up video over and over till my eyeballs almost fell out...I see the "free" pawl move quickly towards the center...(brass rods) when it nears the trapped Pawl...no matter what direction it is turning...but when it goes backwards....this action moves it towards the pin..the free pawl then pops out clears one pin and then gets caught on the next..releasing the spring energy.....
Dale
Roger
It does work, that Bat in the ticker video runs with small rare earths.. it just always seemed like cheating to me.. I suspect theres a clever little latch or somethign in there... :)
DHelmick
Cut out a few pawls...
Going to set up a test jig and see what happens..
Negator springs
I have been getting my constant force springs for my kinetic art from SDP in the past. I went to buy some and found they are out of stock. They always seem to be out of stock. I see that the springs are manufactured by Ametek Hunter Springs but they will only sell in quantities of 50 pieces. So is there another source?
Ive only bought them once from vulcan.. min order was 100.00 , turned out they werent constant force..but they worked anyway. Vulcan still doesnt have any I dont think.. Let me know if you find a source.. I may want a couple myself.. Close to time to do a bat as a posted project I think...
I see plenty in stock for the Negator springs...
Different Torques ...Here is an example...$27.69
Spring Torque
5.5 lb-in
Fatique Life
2500 Cycles
Spring Length
175"
Spring Thickess (t)
0.01"
Spring Width (W)
0.625"
Material
301 Stainless Steel
Drum Size(storage)
1.28"
Drum Size( Output)
2.23"
Spring Torque
5.5 lb-in
Fatique Life
2500 Cycles
Spring Length
175"
Spring Thickess (t)
0.01"
Spring Width (W)
0.625"
Material
301 Stainless Steel
Drum Size(storage)
1.28"
Drum Size( Output)
2.23"
The size I need are the ones 3/8" wide. They report out of stock. I'm not positive but thinmk that is what daid used.
DHelmick wrote: I see plenty in stock for the Negator springs...
Spring Torque
5.5 lb-in
Fatique Life
2500 Cycles
Spring Length
175"
Spring Thickess (t)
0.01"
Spring Width (W)
0.625"
Material
301 Stainless Steel
Drum Size(storage)
1.28"
Drum Size( Output)
2.23"
