Problem with involute gear generation
Re: Problem with involute gear generation
Scott:
  You may be better off holding on a day or two, its looking like the new routines will be out within 2-3 days, so youll have amuch easier time seeing what you get, and creating
paths in various ways. Its easier to see if a tool is too large, and to see why a path may be messing up.
The video I posted was an early test of the simulation showing the generated paths, so by end of week at the latest you should be able to do it yourself.. I know the old
routines are very hard to see and very bad to follow , which is why the new routines are being developed. So rather than fight whatever the issue is, I suggest you take a break for a couple of days, Im just completing the GCode output section, the paths are all working fine at the moment, Im betting your problem will go away, or at least show
us whats up when you get your hands on the new code. I expect Ill be doing a video shortly on its usage..
Scott Pancheau
Post by Scott Pancheau »
Thank you Art,
And I did figure out changing the dp for different sizing.
Scott
Users browsing this forum: No registered users and 263 guests
