New version 1.19
John S
Re: New version 1.19
Post by John S »
Brilliant, better than the ones fitted in my Bridgeport.
The screen allows you to set a tolerance, but I used .1 on the ball bearings and .3 on the roller bearings.
I made the module because I wanted to be able to make 2-3" OD bearings for wood projects and such that
would have the appearance of home built... Probably useless to most, but hey..it was fun.. . :)
John S wrote: Brilliant, better than the ones fitted in my Bridgeport.
How do they compare to the ones on your Blidgeport?
Just a note, I updated the current version to correct a small CNC posting bug, and thenew version has Racks that can be created
on the non-circulars page. ( A rack being quite non-circular.. :) )
  I havent finished tieing the racks in quite yet, but you can create them and post the models and code for them.
I can generate a rack but no wheel to go with it - is that where you are at with the rack or is there a little bug?
  Racks arent finished as yet for the simulation, you can create one for output, but you cannot join it with anything ( in your version anyway :) ), as yet. Next version will have more ability in using and simulating with racks.
Video for bearing usage is on Youtube at
https://www.youtube.com/watch?v=PWAvqnh ... e=youtu.be
(Not that a tutorial is required for them. :)
Racks tutorial in production..
