Version 2.298 online.
Ken_Shea
Re: Version 2.298 online.
Post by Ken_Shea »
Win 7 pro, 64 bit, Microsoft LifeCam Model 1393, latest drivers
Camera shows up, the resolution selection is blank, defaults to 640x480.
Ken
Version 2.2982 is online with better camera selection code. Id be interested if it helps in anyones system.
I tested this with 2 camera's installed, and could choose between the two with various resolutions.
danmauch
Post by danmauch »
Just to let you know that I too have a logitech 9000  and it it finds my camera with no problem.
Win 7 32 bits
brand468 wrote: Hello Art, Stereo Photometric can not find my webcam (Logitech Pro 9000).
I've tried to reinstall drivers but still cant find the camera.
The camera works well in Logitech's own program.
Any suggestions to try or is it better to get a Microsoft camera?
Best regards
Christer
Ken_Shea
Post by Ken_Shea »
Haven't yet downloaded the latest version, however, once the Microsoft LifeCam software was downloaded and installed (today) the resolution choices are now available in Gearotic.
This Microsoft LifeCam software was shown as available with the automated MS Windows updates and then selected to download.
Ken
thx ken..
  You'll find the new version doesnt repeat resolutions at least. :)
KKirk
Post by KKirk »
Loaded 2.2982.  No differences.  Everything works fine.  No resolutions offered.  defaults to 640 x 480.
Karl
Same results here.
My confidence levels have dropped from high teens/20s to around 10 with the overhead lights off, and and were mid teens with the lights on.  The moosecave has a small window high up to my right fwiw.
KKirk
Post by KKirk »
I've had confidence  levels in the 50's & 60's.  I find that I put a small light (60 watt) behind the monitor in an otherwise dark room, I get the highest results.
Karl
brand468
Post by brand468 »
Hi Art, Version 2.2982 found my camera.
I have two cameras on my computer and these are interchanged in the program,
otherwise i can create 3d now.  :)
However, I can not create STL, get up text says "Change size of the output of pixels to inches or mm"
brand468
Post by brand468 »
I have tried 1024x768 on my camera and get a confidence of 69.
I use a 40 inch screen in 4k resolution.
brand468
Post by brand468 »
Art, i tried again and now it works STL, exported face and imported into Aspire.
Became fantastically well with incredibly fine details, and then I did only a quick test.  :) :) :)
Would be interesting if you could control four powerful LED lights from the program, then you should be able to scan larger items too?
https://www.dropbox.com/s/r9ufiw10n18zw2u/Test%203d.jpg?dl=0
Looks liek things are shaping up anyway.. Thx for the report..
Hi All
  2.2983 is online. The problem, we're having is it seems some cameras categorize their video as one type, others another..yet others even more..
  So this version has most stops pulled. It will, on each line show a subcode..3 sub numbers, please let me know, if this version shows
resolutions and others didnt, what your subcodes are. If you find selections that dont work.. same deal, let me know what doesnt work..
If you STILL show no resolutions, let me know that too, but please confirm theversion number in help/about..
brand468
Post by brand468 »
Art, i can choose all resolutions from 320x240 to 1024x768
on Logitech QuickCam Pro 9000
I get same subcode Sub:0-Sub:0-Sub:0 on all.
Thx, sounds like logitech reports normal on all counts. 0's are standard parsing with stops engaged,
which is a good thing.. :)
