Hi Art:
I get a popup that says, "Error found, Gearotic 9, Attempt Recovery?"
Yes does nothing except blink the popup. No closes Gearotic.
Any idea what I can do?
Gearotic 2.296 crashes when I select the StereoPhotometry Utility
Re: Gearotic 2.296 crashes when I select the StereoPhotometry Utility
Hi Andy:
This error indicates the text module is failing .. Ive addedmore error nunmbers for the next iteration to help
me track this down, your one of 3 who have had this crash, I will update in a bit and announce it so you can download
to retry.. Sorry for the problem, but this module is real young..
Andy:
New version online, let me know what error you get and Ill see if I can fix it for you.
Hi Art:
I tried 2.29700 and I got Error 93.
Clicking on "Yes" gave me Error 1167.
Further clicks on "Yes" brought me right back to Error 1197.
Clicking "No" crashed the program.
Thanks!
Thanks!
Hi Andy:
Sorry, this one will be awhile I think. Your errors give no clue as to whats failing, and I cant find any
clues as to why. Your crashing as it tries to put a message on the screen to select a camera. It may be your camera is
crashing it when the system tries to query it..
Does it crash with no camera plugged in? Does it crash if you select another module first?
Hi Art:
I tried again, going in and adding a couple of gears to the project first, and it still acted the same way.
If it's helpful at all, the pick box for Camera Selection comes up blank.
Andy..
How about if the camera is totally unplugged, none plugged in. ( Or it is a laptop with a permanent camera? )
Contact me offlist at support@gearotic.com and Ill make you a special test tommorrow that bypasses
the section giving you the error.. Im a bit stumped as to what elese to try there...
Hi art:
Sorry, I meant to tell yo that-it is a laptop w/ built-in ca,era.
I tested the camera with a videoconferencing app, and it is working.
Users browsing this forum: No registered users and 115 guests
