Backlash
Ian
Backlash
Post by Ian »
i have just laser cut some circular spur wooden gears  2.5mm Mod and they bind a bit
Can solve the problem by bending the shaft a smidgen
Thought there was a way to add backlash but can't see it or remember
Using GT 2.29
Any tips or hints please
Re: Backlash
Hi Ian:
Set Tooth width to .48 or so, unless its noncircular, then set it to .52..  :)
Ian
Re: Backlash
Post by Ian »
Thanks Art
Knew it was simply
Was tired and frustrated I had done just that on non circular gears duh!
Thanks Ian
Ian
Re: Backlash
Post by Ian »
Found out why I got binding gears the width in circular gears is not remembered
eg set it to 0.48 go non-circular return to circular and it is set back to .5 !!
similarly width in non-circular is not remembered !
Also resets to .5 if exit program next time I run GT
A bright side this has shown up a problem I have with shaft slackness/wobble  :-\
Ian
Re: Backlash
Ian:
Thx, Ill add that to my list.
Users browsing this forum: No registered users and 38 guests
