couple of cosmetic points
Ian
Post by Ian »
Minor points ignore if you wish
  • In version 2.279 you got rid of status bar. This move had side effect of of transparency header not being above transparency slider.
    When using the measure ruler I cant't see the result on my laptop it ends up under the tool pane. No problem if I have my larger monitor connected. Laptop resolution 1366x768, large screen 1920x1080. I suggest measurement shown at the top of the project screen instead of the bottom.
Ian
Ian
Re: couple of cosmetic points
Post by Ian »
Even more minor
In the properties panel for
"cage" they are called "Hypocycloids"
"boxing" they are are called "plating"
Do you want to be notified of this sort of issue or not ?
Realise GT is aimed at hobbyists
Ian
Ian:
 By all means point them out, I wont always fix them, but I do appreciate it being pointed out. While GM is really designed for hobbiests, due to the subject matter being kind of rare, many professionsals use it as well. ( A program that does what G2 does in the professional realm is easily over a thousand a copy..), so
I do like to keep it as nice as I can. (Kinda like running a B&B, you like it to look good enough that anyone can stay even if your designed around the pub crowd pulling in...)..
  I have repaired the above issues for next release. :)
