Post Processor Questions and Suggestions
Re: Post Processor Questions and Suggestions
  I cant easily fix line numbers.. Ill have to list that one as it impacts a lot of Code, BUT .. I have aded
a Feedrate precision specifier to the post file, so you can select as many digits after the feedrate decimal as you like as of next version.
Ill look into other fixes over time.
Mainstore
Post by Mainstore »
Great!
I understand that a lot of people don't want or need line numbers. The offer still stands about uploading my numbering script. I'll remove the kludgy feed rate code. The rest is robust and should work OK for anybody.
Kevin
Hi Kevin:
Sure, drop it here, and Ill check it out and include it in the release files .. if it can help someone..why not. :)
