Have been doing some spokes on my clock wheels, and have come across a little problem. I use origin 0,0 in the centre of the work area when performing multiple operations especially on wheels etc.
I notice on all my computers (Mac & PC) that you can not select the wheel if you have 0,0 in centre table, you have to start at bottom left, select wheel, move 0,0 to centre table then place the wheel correctly. All seems OK after that.
I also note that if you set up a metric tool and use feed in inches (in toolbox) the feed is incorrect, appears to remain in mm.
Like how both 3 & 4 axis are turning out. :)
Regards
David
3D CAM module, Origin and selecting entity
Re: 3D CAM module, Origin and selecting entity
Thanks David:
I will look into both.
David:
Both items should now be fixed if you redownload. Thanks for the bug report.
Thanks for that, amazingly fast fix...as usual!
David
David
