I've downloaded the latest development version and I'm having an issue with the boxing. The boxing does not appear to automatically give me the correct size of "box" because one of the gears extends beyond the edge of the box and the other issue is that tabbing doesn't give be tabs on all sides even though they are checked. I only get top and right side. There may also be an issue with metric on this screen but I'm not sure as it only happened once even though inches were checked the options window.
Boxing Problem
Boxing Problem
Re: Boxing Problem
Hmm, seems to work for me, can you save a project and post it here so I can debug it?
Re: Boxing Problem
I've sent the file by email as it is 5.2 megs.
Re: Boxing Problem
Seems to run fine here, but I did up the number of tabs to 6 and set the depth to .5 from 1.
Ellipticals can fool it a bit, but after hitting "from project" feel free to change the X( width) , Y ( heght) or depth(z) manually to make a box fit.
Tabs should be automatic if the sides for them are enabled. In this case I see all tabs on all sides...
Re: Boxing Problem
Made the changes you did and it works fine for me too!
Users browsing this forum: No registered users and 35 guests
