Undo deletes everything
Stephen Fornelius
Post by Stephen Fornelius »
I tried using undo instead of selecting and deleting.  It cleaned the entire screen instead of just removing the last operation.  I made a file and then I save after every operation, but that's kind of clumsy when I have to open the saved file again.
Steve
Re: Undo deletes everything
Steve:
Really?  The undo shoudl only do one operation back. You arent pressing that icon that looks like a sheet
of paper are you? Thats "New project" or " delete everything".
  The only undo/redo are on the properties tab..
Stephen Fornelius
Nope, I just made up a sprocket, changed the arbor hole and saw that it changed, hit the undo tab and it totally disappeared.  I was watching a tutorial and that's why I tried doing the undo.
Steve
Steve:
  Problem found and corrected for next update.
