Cam Grinding coding
Re: Cam Grinding coding
(;-) They make a LOT of assumptions in that program(;-)
I sure am.ArtF wrote: . Any out there also interested
in cam grinding as an output?
Long wanted to do model engines, had the machines but not the time. Now that is reversed, have the time but no machines except for a small router and a bigger much stiffer one half constructed. Found Gearotic in my search for pulley solutions so bought it to make my own, thanks Art.
Next on the list is a small cnc lathe, 500mm BC, with a special focus on grinding , looking for an old mill table for a base, about 1 meter, to take the 35mm Hiwns.
Cams and cranks have always been the stumbling block for me and a cnc lathe with a focus on grinding should make that a lot less of a pain in the butt. Software for it is a stumbling block though, i have seen the online gcode generator one but don't like being tied to something that could go off line at a moments notice.
I hope this idea is still floating around in your mind somewhere, poised to surface about the time the lathe is finished ;D
As someone else noted, don't need a special machine. Its easy to adapt to a lathe or mill if only some decent software existed. Is it a case of build it and they will come or am I the only loon on the planet :D
Mike
Hi Mike:
Desire noted. :)
Desire noted. :)
2.5D or 3D printed cams that don't require a 4th axis or grinder would be nice, too, if cams ever make it to the top of the list.
CAM was an unfortunate choice of acronym, makes googling (or binging :) ) for cam creation a lot harder.
Hi Kirk:
The next module is making a gear ( or cam) from a formula you enter. SO a 3d printed cam isnt far away...
