New version 1.19
New version 1.19
  New version to correct a simulation bug with rotation of geneva's.
Also , for 3d printing, Bearings may now be made. ( See Bearing tool button.)
 Take note, your 3d printer must be very good to print a working bearing, and near excellent to
use roller bearings. (Photo shows 4 working bearings from my Up! mini printer. ) , the roller
took some time to clean up, the ball bearings worked very quickly with not much cleanup. I suspect a powder printer
would be best for these.  :)
				Steve West
Re: New version 1.19
they look really nice,
what sort off tolerance gap do you use between parts ?.
Brilliant, better than the ones fitted in my Bridgeport.
Nottingham, England
						Nottingham, England
The screen allows you to set a tolerance, but I used .1 on the ball bearings and .3 on the roller bearings.
I made the module because I wanted to be able to make 2-3" OD bearings for wood projects and such that
would have the appearance of home built... Probably useless to most, but hey..it was fun.. . :)
How do they compare to the ones on your Blidgeport?John S wrote: Brilliant, better than the ones fitted in my Bridgeport.
Just a note, I updated the current version to correct a small CNC posting bug, and thenew version has Racks that can be created
on the non-circulars page. ( A rack being quite non-circular.. :) )
  I havent finished tieing the racks in quite yet, but you can create them and post the models and code for them.
I can generate a rack but no wheel to go with it - is that where you are at with the rack or is there a little bug?
  Racks arent finished as yet for the simulation, you can create one for output, but you cannot join it with anything ( in your version anyway :) ), as yet. Next version will have more ability in using and simulating with racks.
Video for bearing usage is on Youtube at
https://www.youtube.com/watch?v=PWAvqnh ... e=youtu.be
(Not that a tutorial is required for them. :)
Racks tutorial in production..
