Version Update
Re: Version Update
Fixed my issue with the missing HEAD, now displayed. :)
went to the "C:\Program Files\Gearotic Motion" folder
Right clicked on GearoticThoughts.exe
Selected Compatibility Tab; Privilege Level: check box to "Run this program as an administrator"
Re: Version Update
Amazing.. Now why the heck would microsoft make loading a file in a program an issue of security. Some days I just shake my head...
Re: Version Update
I found it hard to believe that as many people that have tried GT have not had the same issue. Made me think it was something with the graphics driver on this Lenovo laptop. Guess not! Ya-Nvr-No :-\
Re: Version Update
Thanks Ya-Nvr-No
I'm running Win 7 and I also did not see the head, I follow your instructions and now I see the Head ;D
Re: Version Update
I would need a little help ???
I notice that when I go into the cnc mode to gen code for a pulley or gear I'm confused with what should I turn my OD measurements to. As per example one place says OD to be 2.0165 and in the settings shows it to be 2.1414 about .125 difference. Would the larger OD the rough size that I should turn the OD to?
Also the radius does not add up with any of the OD
![Image]()
Re: Version Update
Hi :
Sorry about that, there isnt much documentation on that subject as yet. You should make the blank to the size shown in the information for outside diameter
of that gear on the project screen. The stock display is rather loose in that its just trying to make a blank for display, Ill check why its saying differently, but your stock should be the same size as whatever is reported as the external diameter. All cuts are based on that.
Re: Version Update
thought I'd replace the HEAD with a compass I made in Rhino
just an alternative, now that it displays for me, :D
- compass.zip
- (233.26 KiB) Downloaded 314 times
Re: Version Update
Yes, the Head s replaceable as it is really just an stl file... :)
