When you do gears with many teeth, the toolpath shows on top of the tooth, doesn't seem to hurt anything. (See screenshot).
Gear problem in GT
Re: Gear problem in GT
Interesting.. Ill check that as well, Ive already fixed the previous trouble. This almost looks like an even/odd miscalculation... either way, Ill fix it up..
thx for the bug..
thx for the bug..
Hi Sky:
Just a note, for the next version both troubles have been fixed and the involutes and epicycloidals now
do a radial rooting step as well to shave the side walls once to remove any aliasing artifacts..
