Time for a test of GT if your up for it.
Re: Time for a test of GT if your up for it.
  You can, but only with pulleys, sprockets and round gears. You can save and reload a project and put out papaer printouts or STL modeals as saved files. 2d DXF will very shortly be ready s I decided to get that running as I ponder the best way to do the toolpaths we'll need.
I failed the intuition test - I can't figure out how to the get the gear from the "tools" screen to the "project" screen.  I can change parameters on the tools screen and I can name and save the project but of course there is nothing on the project screen.
I'm missing something obvious in how to put things on the project screen.
  My fault really..I use a large monitor. Drag the gear tool screen upwards..buttons will
appear to place wheel or pinion... from there youll be fine I suspect. :)
Thanks - that solved the project screen problem.  Naturally I play with spokes and they don't always regenerate for me and I may have to change from epicycloid to involute and back again to get the spokes to generate.
Another thing is that I managed to put a pinion gear on the wrong gear.  In GM a right click would allow a delete - now that doesn't seem to work or is it just too soon in the development.
All sorts on new neat stuff on the screens - its fun exploring.
Hi John;
  Delete will show up soon, probably by next test .. There are few safeties at the moment, so you CAN place almost anything on anything.
Its all still "roughed-in" pretty much as yet, its taking shape, and personally I like the new interface much better than the old, but we'll see how it holds up in testing. :)
ozzie34231
Post by ozzie34231 »
Played with timing pulleys; can't move once placed; can't delete, (I see above).
Looks like you can't make a flying change between metric and imperial; must restart prog?
Looking Good
Ozzie
Ozzie:
  Thx, was primarily a test of if it ran or not. Next version will have re-place item, and delete item..
David Sohlstrom
Post by David Sohlstrom »
Just started playing with GT. Any update on when next program update will be.
Dave
Dave:
  I expect within 3 weeks for a beta release of all modules completed so far.
Should be pretty functional, but some modules will be up to a 1-2 months
after that. Id like full functionality up to GM level before XMas.
