Plateing
Ren? Olivier
Plateing
Post by Ren? Olivier »
Hello
I am working on my first wooden clock and I would like to know why when I create the plate from the design this part is not centered with the gear design
Re: Plateing
Rene;
When you generate plating for a clock in GM, you get to specify the size of the case by entering numerical values for depth, width and height, while the center of the case will always be based from the center of the dead beat gear iteself. You can click "clock face"  to round off the top of your case often found on traditional clocks but the center is always located as I mentioned in the center of the beadbeat gear itself. When you export the plate as a dxf from GM, you can always then move the profile around using a CAD program to adapt to your needs as long as all shaft holes remain the same on the plate and that front and back plates are aligned properly so they match up.
Re: Plateing
Rene:
  As Bob says you can set the width, height and depth of the plates, but you can also center them. While on the plateing screen, click the button for front view then grab the plates as a group and center them, then press the button for a side view, then recenter them again. Then do from the top view if you like. By the time youve done all 3, the plates will be centered in any way you wish. :)
Ren? Olivier
Re: Plateing
Hello
Thank for your help
Users browsing this forum: No registered users and 270 guests
