4th Axis tool zero be changed
Mpelsue
Post by Mpelsue »
Gearotic version 3.07. Can the 4th axis tool zero be changed from top center "Z+" to Y+ or Y-? New to CNC. Using a Taig Mill converted to CNC with MACH4 controller software. "A" axis configured and is set for X++.
Thank you
Mark
Mpelsue
Re: 4th Axis tool zero be changed
Post by Mpelsue »
Resolved tool zero issue. Helps if you select correct tool type (Slit Saw) in tool crib.
Hi Mark:
Glad you found it. Sorry for the delayed response, system didn't alert me till today of your message. Ill have to give it a kick..
Users browsing this forum: No registered users and 80 guests
