hello,
do not understand this
<img src="https://www.imgbox.de/users/XLmoby/gear ... nannt1.JPG" alt="Bilder hochladen" border="0"></a>
shaft hole should be 49.7mm. But on the other side of the bevel it is smaller??!!
<img src="https://www.imgbox.de/users/XLmoby/gear ... enannt.JPG" alt="Bilder hochladen" border="0"></a>
when i load it in my printer software it looks like this.
<img src="https://www.imgbox.de/users/XLmoby/gear ... nannt3.JPG" alt="Bilder hochladen" border="0"></a>
all i wanted was a straight hole.
can you help me?
Johannes
shaft diameter wrong
Re: shaft diameter wrong
Hi Johannes:
Can you post a screen shot of the entire screen so I can duplicate this. It looks as if there is missing sections in this gear, perhaps
due to a shaft size too large for the initial creation. Let me duplicate it and Ill let you know what I think is going on.
here are the screen shot.
All i need is the outer ring with teeth. that was the reason for the big shaft.
Thans for helping.
Johannes
[/URL]
[/URL]
Thans for helping.
Johannes
This looks like an error in the way the bevel gets designed internally, it assumes the shaft will not take more then a certain
distance from center to allow for the top tip to emerge properly. I have flagged this as an error for correction.
You might want to try generating the bevel in Ticker, it makes a better manifold for bevels.
