Any help would be great, I am new to using Gearotic and could really use some help. Needing an internal involute spline .dwg/.dxf for the following;
Number of teeth : 13
Spline Pitch : 8/16
Pressure Angle : 30deg
Base diameter: 1.407
Pitch Diameter: 1.625
Major Diameter: 1.767
Form Diameter: 1.754
Minor Diameter: 1.506/1.510
Desperate need for a internal involute spline gear .dwg/.dxf
Re: Desperate need for a internal involute spline gear .dwg/.dxf
Open the circular gear tab,
Set pressure angle to 30 degrees.
Set DP to 8
Set stub to .5
Press regen
A DP 8 stubbed by .5 is a DP8/16 spline.
Hope this helps,
Note:
This post was edited as for some reason I keep thinking its shift, instead of stub...
Set DP to 8
Set stub to .5
Press regen
Hope this helps,
Note:
