parts arrived for pokeys end . its behaving perfectly on the bench .
decided to calibrate the mpg to match the 100 indents per turn it has . its now set that 1 click is 0.1mm on slow and 1.0 mm on fast. will see how that works out in real life.
still waiting for lipo battery and usb charge manager to finish the job
auggie with mpg
Re: auggie with mpg
just tried it out on the k40 , it works just like a bought one !
0.1 mm steps @ 900mm/m is ideal for positioning the laser , 1.0 mm steps @1800mm/m is way too fast for the k40 bed .
0.01 might be needed for touch off on the mill .
i have set the mpg up to have 3 axis's, each can have its own steps/mm setting stored in eeprom , with a built in setup menu.
Re: auggie with mpg
main reason behind this project was to make zeroing laser to the work easier . unfortunately just noticed that the laser test fire button is inoperative when mpg mode active , kinda defeats the purpose . defeat snatched out of the hands of victory.
now I need to build a red dot system too, unless anyone has some bright ideas
Re: auggie with mpg
built one of these as a test , it works nicely but manually
https://www.thingiverse.com/thing:2560096
the pictures don't do it justice the dot is really small and sharp ,easily defined .
now for a automatic depoloyment system.
Last edited by Richard Cullin on Sun Aug 05, 2018 5:52 pm, edited 1 time in total.
Re: auggie with mpg
I've been kinda offline for a while and likely missed something in this discussion...Richard Cullin wrote: unfortunately just noticed that the laser test fire button is inoperative when mpg mode active , kinda defeats the purpose . defeat snatched out of the hands of victory.
On my stock controller K40 the laser test fire button connects to the power supply and bypasses the controller, so it shouldn't matter if there's a pokeys or mpg. The power supply also has it's own laser test button, guessing that just parallels the one on the control panel. Is yours wired differently?
Is the loc-line fitting for an air assist? Is it epoxied on? I've got the lightobject air assist head, but it doesn't work very well with my 65 lpm aquarium pump; I think the air inlet ID is too small for the pump's pressure despite having bored it out.
Re: auggie with mpg
yes I guess it is . the k40 psu has two inputs to control the laser , first is an active low digital line to enable/disable laser powerIs yours wired differently?
second is a 0 to 5v analog input to control the laser power level. I have the auggie controlling both of these inputs. while its possible to " wire or "
the enable line but the analog input would need a switch to be either auggie or manual. I'm sure connecting the analog signals directly would have adverse effects. at design time I felt it best to just disconnect all the k40 controls for simplicity as the auggie laser panel had all the buttons that were needed.
one benefit of the visible loc laser is it makes mirror alignment dead easy.
correctIs the loc-line fitting for an air assist?
worse ,hotmelt glueIs it epoxied on ?
I have a air assist head to too but I find it makes getting work in/out of the k40 awkward since its so much closer to the work I've got the lightobje ct air assist head, but it doesn't work very well with my 65 lpm aquarium pump; I think the air inlet ID is too small for the pump's pressure despite having bored it out
so now I am now using a 3d printed nozzle from thingverse with a nice quiet airbrush compressor. seems ok
problem with plastic nozzle is it can melt catch on fire if the air is not turned on ???
Users browsing this forum: No registered users and 143 guests
