Richard:
On the dropdown ribbon menu select "Connection", the pokeys(s) you are using will be shown, there is a button
on the resultant dialog that allows you to save or load a pokeys internal state.
I suspect this is the best way to swap between programs, but I think I have to spend some time to make it more bulletproof as
a way of storing its auggie state. I think Mach4 ( or 3) will reconfigure the pokeys properly on run anyway as they store all the config
locally.
auggie with laser diode on pokeys57cnc
Re: auggie with laser diode on pokeys57cnc
thanks art , I did not even register that icon as a button
I can report that saving and reloading profiles is a successful remedy . live and learn
cheers richard
cheers richard
Richard:
Ahh, thx. I hadnt tested it in awhile. I added that button when I found testing Mach4 was screwing up Auggies settings. It doesnt work perfectly .. but its nice to know it mostly works. :)
