Functional overview
Re: Functional overview
Post by Richard Cullin »
thanks art , while your lookin  is there a bog standard ccitt  crc code in there anywhere ??
Ya-Nvr-No
Post by Ya-Nvr-No »
do these hex values need to be sent as a string?
Code: Select all
global  myser = Serial();
global  vfd={"0x01","0x03","0x01","0x01","0x31","0x88","0x00"};
global  VFDOpen = function()
	myser.Open(6,9600); //port 6 baud 9600
	print( "VFD opened");
       return;
global SpindleOn = function()
vfd0=ToString(vfd[0]);
vfd1=ToString(vfd[1]);
vfd2=ToString(vfd[2]);
vfd3=ToString(vfd[3]);
vfd4=ToString(vfd[4]);
vfd5=ToString(vfd[5]);
vfd6=ToString(vfd[6]);
  sendData=(vfd0+","+vfd1+","+vfd2+","+vfd3+","+vfd4+","+vfd5+","+vfd6);
print(sendData);
    myser.SendData(sendData);
    print("Set to Frequency " + GlobalGet("SpindleSpeed"));
    myser.Close();
    return;
global VFDSpindle = function(control)
  FreeSetSpeed( MySpindleAxis,control); //turn on/off spindle
  if(control ==1){
    print("Spindle On");
    SpindleOn();
  else
    print("Spindle Off");
   //SpindleOff(); // need to call/Create the Off function
VFDOpen();
VFDSpindle(1); //1 is on 0 is off
9:52:510  VFD opened
9:52:513  Spindle On
9:52:516  0x01,0x03,0x01,0x01,0x31,0x88,0x00
9:52:519  Set to Frequency 0
not as such ,more like a byte array ie whats required and not only that  0 (null) is a likely value I will need to transmit and  that usually terminates a string in most pgm languages
what I need to send is  chr(1)chr(3)chr(1)chr(1)chr(0x31)chr(0x88)
sendtable() or sendbyte()  or sendchr() would do it
.SendData  sends  0x31 0x33 0x31  .......  ascii  values
Hi Richard:
    I can see its very difficult to send proper data to hex code devices.. so Ive add a couple functions to
make it easier.
global  vfd={0x01,"sometext",0x01,0x01,0x31,0x88};
myser.Table = vfd;
myser.SendTable();
myser.Close();
    The above fills the serial channels Table object with the data from your VFD command table.
The command SendTable sends the table, it can send mixed strings and hex codes. It knows from the
type of data in the table how to send it.
Alternativel, you can use
myser.SendHex( 0x45 ); to send a byte without using a table..
The new version is now online that had this capability.
Hope it helps,
I looked into the VFD's ..  They have two modes, an ASCII communications mode and an RTU mode. ( Remote terminal unit.). RTU is what your using..
so for a command like
1,3,1,1,crc  will turn spindle on cw
a,b,c,d,e
a = address of invertor,
b = 1- Read data, 2 - write data, 3 - command, 4- read status, 5-set frequency data.
c = number of data bytes..
d = (data bytes) if command -> run, 1 = fwd, 2 = rev, 3 = stop, 4 = r/f 5 = Jog, 6 = Jog+, 7 = JogR
e = crc
so the above is invertor1, function (command), 1 data bytes, data is command #1(fwd), crc
this document shows the commands and structure.. and how to compute the crc byte. So Id advise
to build a library function with a global list of commands in table form..
ie:
global  VFDSpindleOn={0x01,0x03,0x01,0x01,0x31,0x88}
global  VFDReadFreq={0x01......}
etc
(Im not sure why the 0x88? Manual says the command ends at the crc of ox31..if 31 is the right crc..)
send that command with
myser.Table = VFDSpindleOn;
myser.SendTable();
That should work, though I have no vfd to test the theory on..
thanks art  I will try it out  asap.
I wish if possible to keep it in rtu mode to maintain compatibility with mach3 -hauyung_dll  , it would be a pita to need to reprogram vfd every time to swap controllers.
in rtu mode the crc is 16 bits it uses the ccitt crc16 algorithm, the manual lacks detail  to put it mildly
Code: Select all
public uint  crcc=0xffff; // initialise the crc
void crc16(byte crc_in){   //  crc a byte
      byte c ;
      crcc = crcc ^  crc_in ;
&nbsp; &nbsp; &nbsp; for (c=0;c<8;c++){
&nbsp; &nbsp; &nbsp; &nbsp;  if (crcc&1)
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;  crcc= ((crcc>>1) ^0xa001 )&nbsp;  ;
&nbsp; &nbsp; &nbsp; &nbsp;  else
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;  crcc= crcc>>1;
&nbsp; &nbsp; &nbsp; }
so far so good , one little weird bit
myser.SendTable();
does nothing &nbsp;unless preceeded with a senddata() &nbsp;at least once
so I did it this way &nbsp;, result below &nbsp; :)
Code: Select all
global &nbsp;Vfd_Open = function()
myser.Open(6,9600);
myser.SendData("123");
print( "VFD opened"); &nbsp;
 &nbsp; &nbsp;
 &nbsp; &nbsp;vfd={0x01,0x03,0x01,0x01,0x31,0x88};
 &nbsp; &nbsp;myser.Table = vfd;
 &nbsp; &nbsp;myser.SendTable();
 &nbsp; &nbsp;//FreeSetSpeed( MySpindleAxis, GlobalGet("SpindleSpeed")); //turn on spindle
 &nbsp; &nbsp;print("Vfd Spindle was turned on");
 &nbsp; &nbsp;print("Set to Frequency " + GlobalGet("SpindleSpeed"));
}; &nbsp;
Last edited by Richard Cullin on Wed Jan 04, 2017 11:49 am, edited 1 time in total.
not sure whats happening here ,&nbsp; vfd[3] and vfd[4] don't get sent at all they just vanish
&nbsp; &nbsp; if( Engine.GetSpindleState() != 0)
&nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; print("speed set to " + speed);
&nbsp; &nbsp; &nbsp; vfd={0x01,0x05,0x03,0,0,0,0x70,0x45};
&nbsp; &nbsp; &nbsp; freq=speed/55.0;
&nbsp; &nbsp; &nbsp; freq=freq*100;
&nbsp; &nbsp; &nbsp; vfd[3]=freq/256;
&nbsp; &nbsp; &nbsp; vfd[4]=freq%256;
&nbsp; &nbsp; &nbsp; //FreeSetSpeed( MySpindleAxis, speed);
&nbsp; &nbsp; &nbsp; print("Frequency&nbsp; set to " + freq );
&nbsp; &nbsp; &nbsp; myser.Table = vfd;
&nbsp; &nbsp; &nbsp; myser.SendTable();
&nbsp; &nbsp; }
};&nbsp;
this could work but fh/fl must be constants if they are the result of a calc nothing gets sent
ie&nbsp;
fh=freq/256&nbsp; ;&nbsp; nothing sent after vfd table
fh=int(freq/256);&nbsp; the script fails completely in that nothing is sent at all
&nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; vfd=table(0x01,0x05,0x03);
&nbsp; &nbsp; &nbsp; fh=0x27;//int(freq/256);
&nbsp; &nbsp; &nbsp; fl=0x10;//int(freq%256);
&nbsp; &nbsp; &nbsp; FreeSetSpeed( MySpindleAxis, speed);
&nbsp; &nbsp; &nbsp; for (inx=0;inx<3;inx+=1)
&nbsp; &nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; myser.SendHex(vfd[inx]);
&nbsp; &nbsp; &nbsp; };
myser.SendHex(fh);
myser.SendHex(fl);
&nbsp; &nbsp; };
};&nbsp;
Hi Richard:
I suspect its using floats ..
try
vfd[3]= ToInt(freq/256.0);
vfd[4]= ToInt( ToInt(freq)%256);
>>does nothing&nbsp; unless preceeded with a senddata()&nbsp; at least once
Ill check that.. shouldnt be..
ToInt()&nbsp; does the trick for sendhex , will try table again
thanks
ToInt()&nbsp; does the trick for sendtable too&nbsp;
next step crc calc
No problem, glad to know VFDs can work in Auggie. Ive been burning tests again lately,it &nbsp;feels good to be using it
again, I've been so busy coding I hadnt done much cutting. Auggie impresses me more each time I use it lately.
&nbsp;I see errors I need to fix and small troubles I'd like to change, but overall its treating me pretty good, like an old
reliable, turn it on and it burns..
&nbsp;Each of your troubles has fixed a primary interface, so it shows how much testing can help. YaNvrNo helps me a
tremendous amount in primary testing , Ive crashed him hundreds of times.. (probably thousands..), so I
really have to hand it to him for stamina. The result is a controller thats a bit scary internally as it does so many things,
but for all that probably as reliable as Mach3 is on my mill at this point, better in terms of starting over or after a
pause. Never thought Id make another controller..but this one is purely for fun, that's why its free. &nbsp; So keep testing.. :-)
&nbsp;
Good luck
Richard:
Ill look at adding a crcfromtable command..
