I do not know G-code well, but my emulator reports an illegal syntax at line 10 in the generated code. The plunge rate is set to 1000.0 in the ToolBox options.
Is the 'F' character missing in front of 1000.0 in line 10? Is this a bug or is the 'F' not strictly needed?
Version used: Gearotic 2.30080, problem easily repeatable, occurs many times in the G-code.
1 ( No Prolog Set )( GCode Objects Begin. )
2 ( Object Spur Begins )
3 G0 X0.027 Y-0.499 Z2.000 A0.000
4 ( Shaft Hole path - Inside Profile )
5 ( Tool --: EndMill2mm posted as T1 )
6 M5
7 M6 T1
8 G43H1
9 M3 S12000
10 G1 Z-3.000 1000.0
G-code generated by 3-axis CNC - is this a bug?
Re: G-code generated by 3-axis CNC - is this a bug?
Hi :
Ouch, yes, that looks like a bug. Are you using the default post processor?
I will investigate and repair.
Hi
I did not change the post processor, so i guess it must be the default post processor.
I am a new user and this is my first project.
Thank you, Alfred.
Thank you, Alfred.
Thanks Alfred:
Sounds like a bug to me, Ill get it fixed right up, surprised it hasnt happened to me yet, but various systems can see
bugs others cannot depending on settings. Ill post a note when a fix is done..
Hi Alfred:
New version 2.3009 fixes this error. Thx for the notification.
