Shared Functions()
GlennD
Re: Shared Functions()
Post by GlennD »
Thank you for the explanation.
A quick question on the SetText and GetText if you have time.
I have a button I want to change its text based on the state.
I started my button id as just 0 or 1 initially then thought I would add a 700 in front maybe to differentiate them.
Here is the different examples to see if I could get the text from a button.
Figured if I went that route I could figure out how to set it from there.
Since I tried a bunch of different iterations last night and today on the SetText with no luck.
Code: Select all
mTxt = Button(Main_BUT_7002).GetText;
mTxt1 = Button("Main_BUT_7002").GetText;
mTxt2 = Button(Main_BUT_7002).Text;
mTxt3 = Button(Main_BUT_7002).text;
mTxt4 = Button("Main_BUT_7002").Text;
mTxt5 = Button("Main_BUT_7002").text;
but= Button("Main_BUT_7002");
 mTxt6 = but.GetText;
"but" does show the hex val of the Main_BUT_7002
As you can see the .GetText gives a function:_native
The .text and .Text stay as null.
I even tried getting the text of a label same results.
A perfectly good answer is it is not hooked up yet and I can wait.
Or numb skull do it this way or that ain't happening.  :)
Glenn
Hi Glen:
  There are a couple ways to do that really. The way I recommend is to use
mybut = Button("Main_BUT_88");
mybut.SetText("New");
  to get the text you can do a
text = mybut.GetText();
  FYI:
    When your typing these things, type the words  "mybut = Button"", then left shift and click the button,
the rest will fill in for you.. If a button text doesnt set.. check its ID is unique..
GlennD
Post by GlennD »
You forgot the you numbskull part.
I tried everything except the parentheses.  :D
Ya-Nvr-No
Post by Ya-Nvr-No »
You might like Dialog popup boxes too, in this example called with a screen button named "Main_BUT_45"
Code: Select all
global  TestDlgs = function(current)
  print(current);
  dlg=Button("Main_BUT_45");
  if(current == 1)
      a = Dlgs();
      b = a.GetCoord3("Enter 3 coords:", "x", "y", "z", Vec3(4,5,6));
      val0=(b[0]);
      val1=(b[1]);
      val2=(b[2]);
      print(b);
      print(val0);
      print(val1);
      print(val2);
return;
Ya-Nvr-No
Post by Ya-Nvr-No »
Here is an example CheckHomed(); of how to change the axis DRO's font color based on the homed condition.
I used a button to call the function to test.
Code: Select all
global x=DRO("Main_DRO_0");
global y=DRO("Main_DRO_1");
global z=DRO("Main_DRO_2");
global a=DRO("Main_DRO_3");
global axis=b;
  x.DrawColor(0x00ff00, 0x000000);
  y.DrawColor(0x00ff00, 0x000000);
  z.DrawColor(0x00ff00, 0x000000);
  a.DrawColor(0x00ff00, 0x000000);
global Homed = function(axis,state)
if(state==1){
  if (axis == 0){x.DrawColor(0xff0000, 0x000000);}
  if (axis == 1){y.DrawColor(0xff0000, 0x000000);}
  if (axis == 2){z.DrawColor(0xff0000, 0x000000);}
  if (axis == 3){a.DrawColor(0xff0000, 0x000000);}
else{
  if (axis == 0){x.DrawColor(0x0000ff, 0x000000);}
  if (axis == 1){y.DrawColor(0x0000ff, 0x000000);}
  if (axis == 2){z.DrawColor(0x0000ff, 0x000000);}
  if (axis == 3){a.DrawColor(0x0000ff, 0x000000);}
global CheckHomed = function()
  state=GlobalGet("Axis1Homed");
  Homed(0,state);
yield();
  state=GlobalGet("Axis2Homed");
  Homed(1,state);
yield();
  state=GlobalGet("Axis3Homed");
  Homed(2,state);
yield();
  state=GlobalGet("Axis4Homed");
  Homed(3,state);
yield();
CheckHomed(); // i use this here to test in the mainscreen script to call the function
Ya-Nvr-No
Post by Ya-Nvr-No »
Found this function today written for MatLab (Created by Feng Cheng Chang); liked it and thought i'd convert it to Monkey script.
Returns the day of the week for a calendar date.
good example of math & table use.
Note: needed to convert "w" to integer to get the table string associated day.
source matlab code:
Code: Select all
function w = Wd(m,d,cy)
 m = m-2;
 if m <= 0,&nbsp; m = m+12;&nbsp; cy = cy-1;&nbsp; end;
 c = fix(cy/100);&nbsp;
 y = mod(cy,100);
 w = mod(d+fix(m*2.59)+fix(y*1.25)+fix(c*5.25),7);
%example
w = Wd(1,6,2016)
%returns
w=3
Converted to Monkey Script :
Code: Select all
global getday = function(m,d,cy)
day = table("Sunday","Monday","Tuesday","Wednesday","Thursday","Friday","Saturday");
&nbsp; &nbsp; &nbsp; &nbsp; m = m-2;&nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; if (m <= 0)
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; {
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; m = m+12;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; cy = cy-1;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; }
&nbsp; &nbsp; &nbsp; &nbsp;  c = math.floor(cy/100);&nbsp;
&nbsp; &nbsp; &nbsp; &nbsp;  y = (cy % 100);
&nbsp; &nbsp; &nbsp; &nbsp;  w = ((d+math.floor(m*2.59)+math.floor(y*1.25)+math.floor(c*5.25)) % 7);
&nbsp; &nbsp; &nbsp; &nbsp;  w = ToInt(w);
&nbsp; &nbsp; &nbsp; &nbsp;  return day[w];
weekday=getday(1,11,2016); // todays date returned as #1 Monday
print("The day of the week was: "+weekday);
Ya-Nvr-No
Post by Ya-Nvr-No »
Been working on an analog clock function that takes the digital values and converts them to polar rotation, then I overlay a dxf file clock face. All cool stuff that can be done with scripting. :) (and then hopefully used to output to the machine controller)
Sorry I'm not very good at capturing the screen display and the correct seconds value,&nbsp; :-[ (I'm old)
GlennD
Post by GlennD »
Stole this shamelessly from the arduino web site and added it to MyGlobals.
You can use it to map a value from one set of numbers to another set.
Say you get a value from a potentiometer and want a duty cycle for PWM out.
Or use it to map spindle speed to the PWM out.
for instance:
SetPWMDuty_1(2,map(GlobalGet("SpindleSpeed"),8000,18000,0.1,100));
Assuming you have a range of 8000 to 18000 rpm on your spindle.
The above would set PWM(2) to the correct range for your spindle if the PWM value was linear to the spindle speed.
The output is an integer value if you use all integer numbers so you won't have finite control over the spindle in that case.
Make sure your Val coming in is a float or one of the other number is at least. &nbsp;
I checked and Pokey can handle a value like 12.3333 in the PWM output.
Code: Select all
global map = function(Val,inMin,inMax,outMin,outMax)
 &nbsp; result = (Val - inMin) * (outMax - outMin) / (inMax - inMin) + outMin;
 &nbsp;print ("Map Result " + result);
 &nbsp;return result;
Glenn
You would have to know what PWM value output the spindle will start at.
Edit:
Another note the Val&nbsp; needs to be a larger number than the inMin so you don't get a negative number.
Will need to test for that before calling the map function.
for instance
Code: Select all
SSpeed=GlobalGet("SpindleSpeed");
if (SSpeed>= 8000){SetPWMDuty_1(2,map(SSpeed,8000,18000,0.1,100));};
Ya-Nvr-No
Post by Ya-Nvr-No »
Running a Gcode program while an analog clock script is updating on the screen, and a very short video
https://youtu.be/qaumU9BthKs
Ya-Nvr-No
Post by Ya-Nvr-No »
Quick video of a function call that uses 3 points to determine the circle radius and center.
I added the code to the beginning to clear the screen and also could show all three calls together. Now it will be part of the Library and as long as the check box is on, it is available to use. I am also using the pattern call from the library to display the points and the center of the circle created from the points.
https://youtu.be/p4Jv4hvptvM
added one to show some graphic patterns and spinning using a function call
https://youtu.be/ndLadbfkC1s
