Version 4.89.1
Posted: Fri May 10, 2013 1:13 am
  Version 4.89.1 is released under dev download. Its only change is the bevel code is redacted to straight flute
code from the experimental taper code. The release download has been upgraded to the dev version 4.89 as its
proved quite stable over the last few months.
    The rewrite in the fall will have both types of bevel Gcode output as well as hopefully a third option of engraving
it laying flat or whatever easier method of construction we can figure out.. :)
