New Version.
Posted: Mon May 12, 2014 1:34 am
  V2.0 of GT ( or Gearotic2.0 as its named now, is online. )
I had a request for 4th axis on planetary gears, for the purpose of moulding them, so this is now enabled ,
and in the process I found some math issues with planetary involutes, that too is now fixed.
    A new module "Boxing" is now released as well. I will release a video on its operation, its pretty simple,
turn on plates, select a perspective button on top to select a view plane and you can center the plates on that plane.
  Plates can be machined in 2.5D only of course and DXF output as well.
  You cannot change the shaft hole sizes that appear in the plates, but Im planning a new module "Decorate" soon to
allow one to modify most of the extrusion types in a cad like atmosphere which will allow individual shaft holes in such
things to be made arbitrary sizes.
