Thanks for the thoughts. I can understand wanting to do it right. I will give the 5-3mm conversion a shot. If you do get the info you need to generate the tooth profile, I will also look forward to that.
Paul
GT2 3mm Pulleys
Re: GT2 3mm Pulleys
Paul:
They are in todays release, BUT be cautious, they look a bit off to me, might not matter, that happens in interpolated data,
but let me know how they stack up.. Thx for the pointer to the data...
Re: GT2 3mm Pulleys
Thanks! I will generate some gears and let you know how they work.
UPDATE: Tried to generate a 10 tooth gear - yes pretty small. It looks like a series of vectors that don't quite tie togehter. I will try to attach a PDF of what the DXF looks like.
When I try to generate a 25 tooth gear I get a Error Found Gearotic:11, Attempt Recovery? - I tried several times to recover and it just loops around to the same error.
Paul
Paul
Re: GT2 3mm Pulleys
Paul;
Have you tried switching over from inches to mm in your setup?
Re: GT2 3mm Pulleys
Paul:
I did discover inch mode wasnt working, a fix was generated so redownload and you should find its fine..
Re: GT2 3mm Pulleys
After too much business travel got back to the gears. The profiles look a bit flat on the tips compared to the other GT profiles. When I cut a 55T gear, the mesh was off with the 180* of engagement. I went to the GT2-5 profile and re-sized it to the proper diameter and it seems to be working fine.
Thanks again for the effort on this. It is pretty nice to be able to knock out a gear for a project as needed.
Now that the rotary is complete, time to get back to the clock!
Paul
Paul
Re: GT2 3mm Pulleys
Paul:
Yes, tyhe shaping can be difficult to get right if the spec isnt just so.. Its why I always hesitate to try to
duplicate a shape unless I have something more definitive. The GT2 I did was based on a belt apparently, so
I expect its a bit off. Ill wait and see what feedback occurs over the years.. :) , eventually Ill find the
right data. Glad to hear the 5mm works when scaled.. Maybe Ill just change the code to scale the 5mm ..dunno why I didnt
just add it that way..
Users browsing this forum: No registered users and 67 guests
