In the simulation tool bar there is just enough room for a box where you could put in the degrees of rotation of the main gear and when you hit simulate it would rotate just that many degrees.
That would be pretty useful to me, but then I don't have to code it.
GT Simulation
Re: GT Simulation
I will put this on list for adding shortly. As of next version the renaming of gears is turned on by the way. :)
