gear thickness and shaft hole
I would like to see a dialog box in the wheel and pinion sections to set the thickness and center hole diameter. I know the shaft hole diameter is in the spoke panel and the thickness can be adjusted before placing wheel or pinion but I think it would be easier to work each gear individually. Say for example a 1/4" thick wheel with a 3/8 hole and a 1/2" thick pinion with an 1/8" hole. I realize everything can be adjusted before placing into the project but it is kind of spread out on the screen right now. Just seems logical as you are entering data to have it all in the same area rather than looking in multiple locations.
Re: gear thickness and shaft hole
Noted. :)
