Crown Gear
Nate
Re: Crown Gear
Post by Nate »
JamesTSG wrote: [spherical teeth] have an undefined (but small) contact surface and engagement angle.  Conventional gearsets have a fixed angle relationship. Deviate by even a small amount from that and bad things happen (uneven wear which induces slop, hooking, broken teeth, etc.).  You would not use them on anything but a CV type joint/pivot.
Maybe I don't understand what "spherical teeth" means.
I had mused on the idea of hinging involute bevel gears, and you can generate a tooth profile (as such) that uses sections of a cone of action that's centered on the axis of the hinge.  Then you can get circular contact "lines" over some range of angles though the self-overlapping nature of the double cone imposes some limits, and there's still a single point of contact at the focus.  The tooth profiles I generated with those assumptions don't look spherical at all, and you sacrifice the offset insensitivity that straight involute gears enjoy.
JamesTSG
Re: Crown Gear
Post by JamesTSG »
Sort of like rounded over peg gears?
Nate
Re: Crown Gear
Post by Nate »
JamesTSG wrote: Sort of like rounded over peg gears?
Dunno.  Here's an image of the model with top land, face and flanks.  I hadn't worked out the rest of the gear shape.
JamesTSG
Re: Crown Gear
Post by JamesTSG »
Uh... whut?
Nate
Re: Crown Gear
Post by Nate »
JamesTSG wrote: Uh... whut?
It's basically only showing the meshing part of the gear.  Maybe this will clarify it.
Re: Crown Gear
Does make it clearer.... couldnt quite see the mesh till then..
Re: Crown Gear
ArtF wrote:so Ill keep adding things, likely till
I cant type anymore
Missed this the first time; there's always voice recognition...
