Optomizing the G code for 4th axis Tangential shaving.
Posted: Sat Sep 13, 2014 5:01 am
One thing I noticed when machining the 17 tooth gear on the A axis was that it tool 36 minutes with a 20 IPM feed rate. I also noticed that there was a lot of time cutting in air (the cutter was off the tooth ) and that the retract distance was way to much. When you work on the simulation and the G code I hope you will look at optimizing the tool path so it takes less time to machine a small geat.
Thanks for a wonderful program.
