CNC not Running Gcode
I have created a simple circular gear, about 4.5 inches in diameter with the latest download of Gearotic (3rd axis generated).  I load it into Mach 3 version 2.0  and the G code loads, I can see it on the Mach3 screen but it won't run the machine.  If I load older files will run fine but not the new one.
Any hints of what I'm doing wrong?
Re: CNC not Running Gcode
Im afraid Ill need more than that. What happens when you try to run it, does it give an error?
Does it show what line it stops on? Usually Mach3's log will report whats stopping it as I recall,
or youll get a message as to what its waiting for?
OK Thanks Art,
Here are some of the things that I have tried:
I have a "design" computer where its warm and a cutting computer in my shop which is only lightly heated.
In order to reduce chances of binging a problem from one computer to another I have done a test on the shop one.
The generation of the Gcode seems to work OK from Gearotic and I get a file to be saved.
When I load into Mach3 (see Photo) there is Gcode there but there is not diagram on the table screen at the right.
I can open the gCode from the edit button and there is lots of code there
When I push the cycle start absolutely nothing happens no message no motor movement just the same screen.
One thing I do notice is that the very first line of the gCode is CB Bot Wheel Support.  That is not the name I had given the wheel that I'm trying to make so - maybe the problem is somewhere in the "post" on Gearotic??
JimG
Post by JimG »
John,
The Status line is reporting "Unknown word where unary operation could be - Line 0" which is the machine not recognising what the text in Line 0 is.    Delete Line 0 or put brackets round it and your GCode should run.
Jim.
That fixed it - I'll have to watch for that next time.  I think its coming off the epi / pro log edit when I post the code.
    Check your ProLogue to make sure it doesnt have that text in it.  It does look like
thats the only real issue though..
