G2 version 2.281
Used calculator in circular gears to set shaft distance of 70mm
which gave a module of
2.97368421052631
went to cage gears on returning to circular gears module was
2.9737 and shaft distance was 69.8820
this happens when going to any tool then returning to circular gears
Also happens to module in cage gears
I haven't checked anywhere else
as another example set module to 2.90006 leave circular tool on returning module set to 2.9001 ie only storing to 4 decimal places somewhere
I noticed this because I was using the calculator in circular gears to get shaft distances for cage gears.
Seems to work if teeth are identical
Any chance of having the calculator within the cage gear tool ?
Hope that all makes sense
Ian
loss of decimal places for module
Re: loss of decimal places for module
Ian:
I do typically limit to 4 decimals, I hadnt though that was too low for MOD..
Ill look into it, and have listed having the calculator on the cage screen as well.
Youll probably see that fairly soon.
You always respond so fast :)
thanks
Ian
thanks
Ian
Thanks for the calculator on cage gears
in the latest version
Ian:
No problem, happy it helps. :)
