cutting in 4th axis
Re: cutting in 4th axis
Joe:
  Not sure what setting you have out of tolerance, but heres a snapshot of my screen on the same gear. I include the numbers
section so you can compare to what you have set. Your toolpath should look more liek this one.. Let me know what was off
if you can, Ill make sure I limit it in the new module this fall...
